AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Automatically linking pictures in Autocad Map?
2 REPLIES 2
392 Views, 2 Replies
I have written a vba program in access that reads a textfile, and stores the
data in a table and then makes an autocadsript that inserts blocks for every
x,y point in the table. Every x,y block is asigned a uniqe identfier so I
can import the access database into autocad and link the x,y points to the
database.
My problem is, that the textfile I import into access, contains a filename
and path to a picture for every x,y point, which I includes in the access
table. Is it possible to somehow link every x,y point with the picture (I
know its possible to do this manually, but since I have several thousends of
points, and every point ha an uniqe ID i was hoping that you could do this
in the same manner as linking every x,y point to the access table.
Marcus Hansson
2 REPLIES 2
What you need to do is add a hyperlink to each block with the file name of
the corresponding image.
If you are already using a VBA app, it shouldn't be too hard to extend it to
do this also...
The hyperlink could get added when the block is inserted or after the block
has been linked to the db.
Cheers,
Will
"Kalle Flink" wrote in message
news:46716309BED237BD64438558B205E59F@in.WebX.maYIadrTaRb...
the
every
> database.
of
> Thanks,
> Marcus Hansson
Marcus,
You should be able to set this up with ADEDEFDOCVIEW (Define Document View)
and then view the pictures with ADEDOCVIEW (View Associated Documents)
Jim B.
the
every
> database.
of
> Thanks,
> Marcus Hansson
”Boost
