I have written a vba program in access that reads a textfile, and stores the
data in a table and then makes an autocadsript that inserts blocks for every
x,y point in the table. Every x,y block is asigned a uniqe identfier so I
can import the access database into autocad and link the x,y points to the
database.
My problem is, that the textfile I import into access, contains a filename
and path to a picture for every x,y point, which I includes in the access
table. Is it possible to somehow link every x,y point with the picture (I
know its possible to do this manually, but since I have several thousends of
points, and every point ha an uniqe ID i was hoping that you could do this
in the same manner as linking every x,y point to the access table.
Marcus Hansson
