Hi Heath,
You can not automatically label your objects during import, but once the SHP
file has been imported into Autodesk Map, you can run a query to label your
drawing objects with the object data. Please see
http://support.autodesk.com/getDoc.asp?id=TS59497 for steps to follow. You
will only need to examine the first half of this solution (steps 1-12). Once
you have defined the query, you can save it and run it whenever you need,
without having to redefine.
I hope this helps.
Andrea Bell
GIS Product Support Technician
"Heath Oliver" wrote in message
news:B0D7C12E7E7FEC40A2770AD8D5174391@in.WebX.maYIadrTaRb...
> I have imported arcview files and can select a street see the name via the
> object data/edit object data. how do i get the names of the streets to
> display. Can I auto matically label them?
