Dear all,
Recently I have purchased the above software to be installed on a 32 bit PC. However, the USB installation that came is 64 bit and the free trial on Autiodesk website, although it offers the 32 bit, is also 64 bit.
It seems that the 32 bit version does not exist. Is there a way around this? I was hoping to download the 32bit trial version and using the serial number and product key of the 64 bit.
Please help
archaeoman
your are right, this suite does not have a 32bit version. And at least it makes sense as in most cases the memory-consumption for projects with Civil3D or Infraworks needs more than the 32bit version can offer.
What applications from the suite do you need most? And don't you have the option for Win7x64 (and more memory)? I see that as the best option (well depending on global knowledge about that suite, but not knowing your processes and workflows).
Sorry, - alfred -
nope no way around it
system requirements are here: http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=16490792
you are going to have to upgrade to a 64 bit OS
DarrenP
