AutoCAD Map 3D General Discussion
Active Member
skenvin
Message 1 of 17 (617 Views)
AutoCAD Raster Design 2010 Object Enabler
617 Views, 16 Replies
10-13-2009 09:08 AM
When down load and try to run AutoCAD Raster Design 2010 Object Enabler I get the following message:
Setup was unable to detect any target applications for AutoCAD Raster Design 2010 Object Enabler.
Anyone have any suggestions?
Distinguished Contributor
snakerancher
Message 2 of 17 (617 Views)
Re: AutoCAD Raster Design 2010 Object Enabler
10-13-2009 09:34 AM in reply to: skenvin
I have found that when I installed Raster design it created a separate folder in C:\program files called; Raster Design 2010 OE. To get Raster Design to run I just moved the files from the Raster Design 2010 OE folder into the AutoCAD Raster Design 2010 folder. Then Raster ran fine. Try that, hope it works.
*Murph
Message 3 of 17 (617 Views)
10-13-2009 10:57 AM in reply to: skenvin
What versions of Map3D are you using or have installed?
Murph
http://map3d.wordpress.com/
"skenvin" wrote in message news:6270637@discussion.autodesk.com...
Active Member
skenvin
Message 4 of 17 (617 Views)
10-13-2009 11:47 AM in reply to: skenvin
Installed are Map3D 2009 and 2010. I kept 2009 just so I can make sure 2010 works before I get rid of it.
Active Member
skenvin
Message 5 of 17 (617 Views)
10-13-2009 11:50 AM in reply to: skenvin
I get this message before it alows me to install
*Murph
Message 6 of 17 (617 Views)
10-13-2009 11:52 AM in reply to: skenvin
Is the 2010 version installed in the default paths?
C:\Program Files\AutoCAD Map3D 2010
I would try the d/l again with admin rights and any anti virus software off.
Murph
"skenvin" wrote in message news:6270780@discussion.autodesk.com...
Active Member
skenvin
Message 7 of 17 (617 Views)
10-13-2009 12:06 PM in reply to: skenvin
2010 is installed in its default. I get the same message whether I try to run from the d/l page or if I save it to a file then I try to run.
*Murph
Message 8 of 17 (617 Views)
10-13-2009 02:29 PM in reply to: skenvin
The one from this page
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13023431&linkID=9240858
and the correct version 32 bit or 64 bit.
Murph
"skenvin" wrote in message news:6270782@discussion.autodesk.com...
Active Member
skenvin
Message 9 of 17 (617 Views)
10-14-2009 05:48 AM in reply to: skenvin
That is the page I got it from, and it was the 32 bit. (raster_design_2010_oe_32_eng.exe)
*wfb
Message 10 of 17 (617 Views)
10-14-2009 06:40 AM in reply to: skenvin
What program do you have that needs the object enabler? Map 2010 doesn't or
does it?
Bill
wrote in message news:6271180@discussion.autodesk.com...
Announcements
Need installation help?
