AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Raster Design 2010 Object Enabler
16 REPLIES 16
Message 1 of 17
skenvin
1065 Views, 16 Replies
When down load and try to run AutoCAD Raster Design 2010 Object Enabler I get the following message:
Setup was unable to detect any target applications for AutoCAD Raster Design 2010 Object Enabler.
Anyone have any suggestions?
16 REPLIES 16
Message 2 of 17
in reply to: skenvin
I have found that when I installed Raster design it created a separate folder in C:\program files called; Raster Design 2010 OE. To get Raster Design to run I just moved the files from the Raster Design 2010 OE folder into the AutoCAD Raster Design 2010 folder. Then Raster ran fine. Try that, hope it works.
Message 3 of 17
What versions of Map3D are you using or have installed?
Murph
http://map3d.wordpress.com/
"skenvin" wrote in message news:6270637@discussion.autodesk.com...
Message 4 of 17
skenvin
Installed are Map3D 2009 and 2010. I kept 2009 just so I can make sure 2010 works before I get rid of it.
Message 5 of 17
skenvin
I get this message before it alows me to install
Message 6 of 17
Is the 2010 version installed in the default paths?
C:\Program Files\AutoCAD Map3D 2010
I would try the d/l again with admin rights and any anti virus software off.
Murph
"skenvin" wrote in message news:6270780@discussion.autodesk.com...
Message 7 of 17
skenvin
2010 is installed in its default. I get the same message whether I try to run from the d/l page or if I save it to a file then I try to run.
Message 8 of 17
The one from this page
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13023431&linkID=9240858
and the correct version 32 bit or 64 bit.
Murph
"skenvin" wrote in message news:6270782@discussion.autodesk.com...
Message 9 of 17
skenvin
That is the page I got it from, and it was the 32 bit. (raster_design_2010_oe_32_eng.exe)
Message 10 of 17
What program do you have that needs the object enabler? Map 2010 doesn't or
does it?
Bill
wrote in message news:6271180@discussion.autodesk.com...
Message 11 of 17
skenvin
Map 3D 2010. I need it to x-ref aerials into my drawings.
Message 12 of 17
Map3D does for SID and ECW files when using the mapiinsert command, with FDO
you don't need it.
Murph
"wfb" wrote in message
news:6271206@discussion.autodesk.com...
does it?
Bill
Message 13 of 17
What format of images are you attaching to?
Murph
"skenvin" wrote in message news:6271225@discussion.autodesk.com...
Message 14 of 17
skenvin
SID and ECW (we have both)
Message 15 of 17
If you use the mapiinsert (note the two i's) does it show those two image
formats in the list? The OE may already be installed.
Murph
"skenvin" wrote in message news:6271281@discussion.autodesk.com...
Message 16 of 17
skenvin
neither show up in the list
Message 17 of 17
Might try a repair install of map3D from the windows control panel then,
something didn't get added to the registry right or something.
Murph
"skenvin" wrote in message news:6271338@discussion.autodesk.com...
”Boost
