AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCad Maps 3D 2011 Seems to Reverted to AutoCad 2011
2 REPLIES 2
dbbykerk
352 Views, 2 Replies
This issue has been solved.
But in a nut shell, My AutoCad Maps 3D 2011 seem to loose all of its Mapping capability. A big indicator was, when I opened a file... The top middle title read as follows - AutoCad 2011 "filename.dwg" opposed to AutoCad Map 3D 2011 "filename.dwg"
I also couldn't complete any mapping functions, no task pane. No map classic workspace... The list goes on and on.
I solved this issue by repairing my AutoCad Maps 3D 2011 Installation.
But does anyone know why this happened?
Thanks for the help
2 REPLIES 2
Alfred.NESWADBA
in reply to: dbbykerk
I guess you lost some path settings, if not verify that you have loaded a Map3D-specific menu as Master-CUI.
My path settings (for Windows7) are:
  • C:\Users\<your login name>\appdata\roaming\autodesk\autocad map 3d 2011\r18.1\deu\support
  • C:\program files\autodesk\autocadmap3d2011\support
  • C:\program files\autodesk\autocadmap3d2011\fonts
  • C:\program files\autodesk\autocadmap3d2011\express
  • C:\program files\autodesk\autocadmap3d2011\support\color
  • C:\program files\autodesk\autocadmap3d2011\fdo\bin
The red parts have to be changed to your needs.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
dbbykerk
in reply to: Alfred.NESWADBA
Thanks for the reply!
I figured that might be an issue, agian, this issue has been solved but if this issue happens agian I will look into the path settings.
Thanks Alfred
Robot Happy
”Boost
