Dear AutoDesk,
we have installed the AutoCAD Map3d 2011 64 bit version on Citrix server.
OS: windows server 2008 R2.
Graphic card: ATI
we are accessing AutoCAD through CITRIX RDP setup.
even after performing the suggested performance tips like "Tool tips,Roll over tool tips off" , selection preview off, dynamic input off. The performance is very very slow.
the cursor in AutoCAD is moving very slowly . we are facing very difficulty to select any feature in autocAD.
is there any way to improve the performance?
is RDP setup is causing performance problem?
Autodesk Team please help us.
Thank You,
Shaik Esu
You might want to try Ericom Blaze, a software product that accelerates and compresses RDP. Blaze accelerates RDP performance by as much as 25 times, and helps deliver higher frame rates and reduce screen freezes and choppiness.
You can read more about Blaze and download a free evaluation at:
http://www.ericom.com/Blaze
Adam
