AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCad Map
1 REPLY 1
etyaf
316 Views, 1 Reply
AutoCad Map
Trabajo con puntos Lidar, originalmente en formato LAS y necesito editarlos clasificandolos en funcion de la intensidad, alturas...
La nueva versión 2013 podrá hacer estas funciones?
Que plugin podria adquirir para realizar la edición de puntos LIDAR
Gracias
J.López
1 REPLY 1
phil_borycens
in reply to: etyaf
Sr. Lopez,
I understand that you wish to stylize a point cloud based on intensity.
This is possible by following the steps outlined in this video:
http://docs.autodesk.com/MAP/2013/ENU/training_videos/Working%20with%20Point%20Clouds.html
Although the video was produced in the 2012 product, the steps are exactly the same for the 2013 product.
You do not need a plugin to accomplish the above, you already have everything you need (.LAS file and AutoCAD Map 3D)
Best wishes to you!
Phil
Phil Borycens
”Boost
