AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D, Windows 2008 and Terminal Services
2 REPLIES 2
552 Views, 2 Replies
Has anyone ran AutoCAD Map 3D through Terminal Services on Windows 2008 R2 X64 ?
2 REPLIES 2
I'm looking to do the same thing with AutoCAD Map 3D 2012 and Windows 2008 Standard 32 bit.  Do you know if that is doable?
NateMoore
Citrix is supported as a way to run multiple sessions of Map and some other AutoCAD verticals from a single system.  WIth other options you'll run into limitations very quickly (and violoate the licensing agreement).  Even for Citrix, you'll need a Citrix specific network license.  www.citrixandautodesk.com has some useful pointers.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
”Boost
