I'm looking to do the same thing with AutoCAD Map 3D 2012 and Windows 2008 Standard 32 bit. Do you know if that is doable?
Citrix is supported as a way to run multiple sessions of Map and some other AutoCAD verticals from a single system. WIth other options you'll run into limitations very quickly (and violoate the licensing agreement). Even for Citrix, you'll need a Citrix specific network license. www.citrixandautodesk.com has some useful pointers.
