AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D to integrate with other systems like Maximo etc
2 REPLIES 2
596 Views, 2 Replies
hi,
i need an information about autocad map 3d ,
What are the integration options available with AutoCAD Map 3D to integrate with other systems like Maximo etc....
2 REPLIES 2
antoniovinci
What file formats is your Maximo able to import, sir?
hence_the_name
not sure what you expect - there is a white paper for map-sap integration.
http://images.autodesk.com/adsk/files/autodesk_sap_whitepaper_en_letter.pdf
As a starter....
Good luck,
Rob
http://raumpatrouille3d.blogspot.ch/
”Boost
