AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D Service Pack 2.1
2 REPLIES 2
381 Views, 2 Replies
After installing Service Pack 2.1 and rebooting PC I checked on Help if it showed that it had installed SP 2.1.  It does not indicate SP was installed but if you try to update it says you already up to date.  Is there any other part I should be looking to verify SP 2.1 was installed?
2 REPLIES 2
You do not mention which version of Map 3D you are using. But, with Map 3D 2013, if you click on the Help tab, then select the About AutoCAD Map 3D 20xx tab, you should see your serial number in the upper left corner of the resulting window, and the product version, with the Service Pack identified underneath that.
Dave
braudpat
Hello
Welcome to the Autodesk/AutoCAD forums !
In your folder (or equivalent) :
C:\Program Files\Autodesk\AutoCAD Map 3D 2013
If you have some DLL / ARX / etc files from July/August 2013 , you have the SP 2 (or SP 2.1) ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
