Not all labels print.
I converted text to an FDO. Not printing
I then converted the FDO to an SDF. Still not printing.
What next?
Solved by Alfred.NESWADBA. Go to Solution.
The default to print FDO labels is set to 2000 (?) You can edit the registry to increase that number. However I don't know what key it is off hand and with the redesign of Autodesk support site I failed to find the link to the white paper on it. Sorry.
there it is: >>>MAX_LABLES in Map3D<<<
- alfred -
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
It's a very OLD limitation of MAP (or CIVIL) FDO Label Engine !
... Same limitation with MAP 2008/2009 ...
I don't understand why Autodesk hasn't increased this value or let a New MAP System Variable controlling the maximum number of FDO Labels !?
The register key "R1x.y" for each MAP is different :
MAP 2010 : R18.0
MAP 2011 : R18.1
MAP 2012 : R18.2
MAP 2013 : R19.0
MAP 2014 : R19.1
Patrice BRAUD
MAP 2015 : R20.0
- alfred -
