AutoCAD Map 3D General Discussion
New Member
athier
Message 1 of 1 (138 Views)
AutoCAD Map 3D 32 bit crash-FDO ArcGIS Provider!
138 Views, 0 Replies
05-24-2013 03:06 AM
Hello everyone,
i have sometime  crashing problems.
in AutoCAD Map 3D 2013 Readme:
In some cases, connecting to a data source with the FDO ArcGIS provider can cause the AutoCAD materials library downloader to go into a loop. If you notice slowdown on your system after connecting to an ArcGIS source, use this workaround to disable the materials library downloader.
Exit Map3D.
Locate AdDownloaderCore.dll in the Map3D install directory, e.g. C:\Program Files\Autodesk\AutoCAD Map 3D 2012\AdDownloaderCore.dll . Rename AdDownloaderCore.dll to something like X_AdDownloaderCore.dll. This disables the downloader.
 Run Map3D again
My question: In any file is AutoCAD materials library loaded? and is it in C:\Users\xxxxx\AppData\Local\Temp?
is it (Library--xxxxxxxx.LayerDefinitionLayer17.gws)
Thanks in advance.
