AutoCAD Map 3D General Discussion
Active Contributor
rckohler
Message 1 of 5 (559 Views)
AutoCAD Map 3D 2013 constant FATAL ERRORS
559 Views, 4 Replies
10-19-2012 12:41 PM
I just downloaded a free trial & was able to import one shape file... The error occured when I tried importing a second shape file. I was able to recover the drawing once starting the program back up. As soon as it opens, the fatal error occurs again. I was unable to get anywhere after that. The imported shape files are only 1MB & 3MB's "large". I was under the impression this is a full trial version. Are there any size restrictions with it? What can I do to fix this issue?
Any help would be appreciated.
Robyn
The only restriction is the 30-day limitation, nothing else is different in functionality from the activated product.
Some questions to isolate the problem (hopefully):
  • Where do you have the SHP-data from?
  • Have you tried to use _DATACONNECT to not import, but reference the SHP-data into your current drawing?
  • What coordinate-system do you use / which coordinate-system comes the SHP from?
  • Do you have any othter product that shows these SHP without errors?
- alfred -
Alfred.NESWADBA
Message 2 of 5 (552 Views)
Re: AutoCAD Map 3D 2013 constant FATAL ERRORS
10-19-2012 03:20 PM in reply to: rckohler
- alfred -
Alfred NESWADBA
Active Contributor
rckohler
Message 3 of 5 (527 Views)
10-22-2012 05:51 AM in reply to: rckohler
I added a few shp files into my drawing using Data Connect. So far, no issues.
Thank you!
Alfred.NESWADBA
Message 4 of 5 (523 Views)
10-22-2012 05:55 AM in reply to: rckohler
does that mean that you can work now as you need?
...or is that just the confirmation for "the shape-files are ok"? (then I miss the answers to the other questions)
- alfred -
Alfred NESWADBA
Active Contributor
rckohler
Message 5 of 5 (517 Views)
10-22-2012 06:38 AM in reply to: Alfred.NESWADBA
Yes, I can work in my file as I need. The shp data is from Michigan GeoRef (MGRm). I am currently using M183-OB coordinate system (meters); which is what the shp files use.
Thanks again for the help!
