Just installed AutoCad Map 3D 2012 and that old annoying problem of windows installer keeps popping up when I run a different application. I've tried copying the geospatial coor. file and renaming it to Geo...."temp" with no success, although it did work with version 2010. Anybody got a solution for this?
Lon
I know the above problem was posted some time ago. I thought I would go ahead and post what I found to resolve it anyway. So others can see it and hopefully fix there problem too.
After copying the "Geospatial Coorinates Systems" to a temp directory. I also had the same problem of the Autocad installer continueing to be a problem. I let the installer run it's course instead of canceling it out. This seemed to resolve this issue, it no long pops up when initiating any other program.
