We recently have been upgraded to Autocad Map 3d 2012. When opening a DWG file that was created in Autocad Map 3d 2011 it is taking an extremely long time to load, It gets to 87% then hangs. The file opens perfectly in Autocad Map 3d 2011 albeit with a minor delay. The DWG file has 4 attached ECW Aerial Photos each stored on a network drive and each greater than 1 GB in Size. I have researched a little and have narrowed it down I think to an XREF issue. The files were attached using the MAPIINSERT Command. I completed a test by opening the base file in Autocad Map 3d 2011 and UNLOADING the 4 images, then saving it. I then opened this file in Autocad Map 3d 2012 and it opened super fast with no DELAY. Can somebody steer me in the right direction on how this can be resolved. I also attempted to open this file on a similar machine and it opens with NO issues. Is it a local setting, registry setting or something to do with memory that I have overlooked, I dont want to attach and detach everytime I open a file with images. It worked fine in Autocad Map 3d 2011
Regards
Paul
1. Check the scalelistedit dialog box for any annotation scales that may be overloading the drawing.
http://rockmaster.wordpress.com/2008/02/15/automatically-purge-scale-list/
I modified the code from the link a bit.
(defun C:scalelistreset
(setvar "cmdecho" 0)(terpri)
(command "-scalelistedit" "reset" "yes" "exit")
) ;eof
2. Check layerfilters and purge any unnecessary layer filters.
An excellent lisp file is written by Mr. Bell
;;;CADALYST 05/04 Tip1949: LFD.LSP Remove Layer Filters (c) 2004 R. Robert Bell
http://cadtips.cadalyst.com/node/tiplisting?keywords=1949
Hope this helps...
you can also delete the annotation scales.
(command "-scalelistedit" "delete" "*" "exit")
