AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Autocad Map 3D 2012/2013 : GRIPS command = 1 not disable the middle Grip
1 REPLY 1
410 Views, 1 Reply
hi,
everuthing is in the title.
It's Ok for plines closed or not but not for Mpolygon.
It's very frustrating.
is it a bug ?
thanks for your advices or workaround
rémy
1 REPLY 1
phil_borycens
Hi Rémy,
Here are my observations from testing in the 2014 release of AutoCAD Map 3D (I always test on the current release first) --
  • GRIPS = 0 deactivates all grips in a mpolygon.
  • Grips behavior is the same for mpolygon under GRIPS = 1 as GRIPS = 2. This is different from the behavior of polylines: when GRIPS = 1, the rectangular grips in polylines are disabled. When GRIPS = 2, the rectangular and square grips in a polyline are enabled.
  • There is a difference between polyline and mpolygon fundamentally - mpolygon objects do not contain rectangular grips. So I can see why they behave the same under GRIPS = 1 as GRIPS = 2.
  • The middle grip in a mpolygon is always for moving the object.
If you disagree with anything here, then that is fine. Just provide an explanation of what you are expecting and why, and I can see about reporting this to Development.
Thanks!
Phil Borycens
”Boost
