AutoCAD Map 3D General Discussion
Active Member
rgourrat
Message 1 of 2 (185 Views)
Autocad Map 3D 2012/2013 : GRIPS command = 1 not disable the middle Grip
185 Views, 1 Replies
10-24-2013 03:17 AM
hi,
everuthing is in the title.
It's Ok for plines closed or not but not for Mpolygon.
It's very frustrating.
is it a bug ?
thanks for your advices or workaround
rémy
Product Support
phil_borycens
Message 2 of 2 (156 Views)
Re: Autocad Map 3D 2012/2013 : GRIPS command = 1 not disable the middle Grip
10-25-2013 12:15 PM in reply to: rgourrat
Hi Rémy,
Here are my observations from testing in the 2014 release of AutoCAD Map 3D (I always test on the current release first) --
  • GRIPS = 0 deactivates all grips in a mpolygon.
  • Grips behavior is the same for mpolygon under GRIPS = 1 as GRIPS = 2. This is different from the behavior of polylines: when GRIPS = 1, the rectangular grips in polylines are disabled. When GRIPS = 2, the rectangular and square grips in a polyline are enabled.
  • There is a difference between polyline and mpolygon fundamentally - mpolygon objects do not contain rectangular grips. So I can see why they behave the same under GRIPS = 1 as GRIPS = 2.
  • The middle grip in a mpolygon is always for moving the object.
If you disagree with anything here, then that is fine. Just provide an explanation of what you are expecting and why, and I can see about reporting this to Development.
Thanks!
Phil Borycens
