I am having a publish problem with Map 2010. When I set my publish setting up and select an entire map to be published when it publishes in multi-sheet it will take some maps and either zoom way in or zoom off the page, which is not how I set them up. I run a script file each night so I publish 200 drawings a night between Midnight and 3 am. Out of those 200 I have 7 maps in which is does this for no reason. I can run the same script with 2008 and there are no problems, but 2010 will do weird things to my .dsd files. Anyone else having these issues with publishing in 2010?
Thanks for your time.
Chad K.
Minot, ND
701-838-9835
