HII having problem with new Map 3d 2015. When i try to create WMS connection, then error occurs: Failed to initialize Fdo connection. Unable to load the FDO Provider library "WMSProvider.dll":(null).
Does anyone have same issue with WMS?
Solved by kajar. Go to Solution.
Hello
+1 with Alfred
Are you speaking about a Patch/Hotfix/SP1 for ACAD MAP 2015 (which corrects some WMS some problem) ??
I can't believe it ! But why not !?
Patrice BRAUD
Cant give you a link to download it, It was possible to download through New tab under notification area. There is also no any update information in Autodesk webpage.
But today I downloaded english version Map 3d trial from Autodesk web and installed it toanother pc(win 7 64 bit) and WMS worked fine , it seems that Autodesk have already changed installer.
So its recommended to download new version and install it.
I was able to get my SP1 from the "Autodesk Application Manager" which was an icon on my task bar. I first had to run an update on that software and then the SP1 was available for installation.
Thx, I already tried that, the SP1 for Map3D is not available through that.
- alfred -
Your link (http://geoservices.brgm.fr/geologie?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities) will not work for me.
I have also Civil 3D 2015 64-bit
Is it possible to release an SP1 for Civil 3D?
The SP1 for Map will not work for Civil 3D
(who is searching for the SP1 for Map: http://knowledge.autodesk.com/support/autocad-map-3d/downloads/caas/downloads/content/autodesk-autoc...
