HII having problem with new Map 3d 2015. When i try to create WMS connection, then error occurs: Failed to initialize Fdo connection. Unable to load the FDO Provider library "WMSProvider.dll":(null).
Does anyone have same issue with WMS?
Solved by kajar. Go to Solution.
Hello
Is it a public WMS Server ? - If YES, please can you give us the Link ?
- Have you tried with MAP 2014 or MAP 2013 ? - If Success (which version ?)
- Have you tried with QGIS for example ?
Patrice BRAUD
I have tried couple different public WMS services but same problem occurs.
With MAP 3d 2014 same WMS server working fine.
One link what working with 2014 MAP 3d : http://kaart.maaamet.ee/wms/alus?
not tried to much, but can reproduce the problem (and it seems not to be depending on a specific server as the message comes before the server is contacted).
- alfred -
Hello from France
Funny !
With my French MAP 2014 x64 + SP 1 (idem with MAP 2013 x64 + SP 2.1) , I see the layers but as soon as I select one ... the WMS connection seems OK ...
BUT I get quickly : a problem has arrived when adding objects to the FDO Map ...
My French MAP 2014 and MAP 2013 don't like the Estonia !
Sorry on my "today" PC I haven't MAP 2015 !
Patrice BRAUD
Same problem with french version of MAP 2015 (x64) with the french national geology wms server : http://geoservices.brgm.fr/geologie
No problem with MAP 2012 and 2014, but error with MAP 2015.
Olivier
I try the URL: http://geoservices.brgm.fr/geologie and it work for me with 2015.
Can you please let me know which OS you are using and it could be helpful to get the build number.
To get the build just type (map_build) to the command line and enter, please send me the result.
I would be also interesting if Map 2015 is always installed on the same PC as Map 2014.
Regards
Brigitte
Hi Brigitte,
ok, that's the thread 😉
Win7 x64 German
AutoCAD Map3D 2015: J.51.0.0
FDO Providers: 3.9.0.0 (I tried to use the 3.8 version of WMS, but that does not work at all)
Not always, but in this case yes, Map3D 2014 is installed too. (Otherwise I would not not be able to use WMS any more 😉 )
Also tried: connect to the WMS-data using Map3D 2014, saved the drawing, opened it with Map3D 2015, failed (translated error message: no rasterdata in this element).
- alfred -
Doesn't work for me either in 2015,
Autodesk AutoCAD Map 3D 2015 Build 18.0.030AK
Window 8 64 bit
MAP 3D 2015 French on Win7Pro64 french, with MAP2014 installed side-by-side => error to load WMSprovider.
Olivier
Hi all,
Thank you for all the feedback.
With a new installation on new operating system I can reproduce the issue and raise it to the development team for investigation.
The reason why it works in my productive environment seems to be the installation of Oracle Client, but this is not an acceptable workaround for AutoCAD Map users to install Oracle Client.
Regards
Brigitte
Hello Brigitte
You said : it's OK with MAP 2015 x64 (and maybe also with MAP 2014 x64 / MAP 2013 x64) because you estimate that your Oracle Client "helps" the connection to WMS ?
And I imagine that you have the Oracle client, because TopoBase ?
Patrice BRAUD
I have Oracle client installed on my machine where MAP 2015 is running. This not helping much.
Brigitte, can you tell also when development team find some cure for this problem. How much we must wait: week, month?
Its really disappointing that Autodesk releases new version without testing it functionality.
End user is like beta tester.
Has there been any further development on this issue. We are having the same problem with a WMS that works in MAP 2014. We were hoping to switch everyone over to 2015 but this is a major inconvenience to doing so.
Win7 64
http://www.valtus.com/wms/servlet/WMSServer
"Failed to connect.
Unable to load the FDO Provider library 'WMSProvider.dll': The specified module could not be found."
>> Now after installing SP1 update WMS started working.
Where did you find a service pack 1 for Map3D 2015?
- alfred -
I don't have that info in my "New Tab".
Can you show the link to the service pack please?
- alfred -
