AutoCAD Map 3D General Discussion
eherc
Message 11 of 31 (875 Views)
Re: AutoCAD Map 2012 cannot start
06-08-2012 04:33 AM in reply to: antoniovinci
Upgrading RAM is the easiest and the cheapest thing, we could pump it up to 12GB on this MB. But we'd be happy with 2012 if we could make it work.
Alfred.NESWADBA
Message 12 of 31 (874 Views)
06-08-2012 04:36 AM in reply to: eherc
>> no, it's not a Dell. And I have already tried with another username, it's all the same.
OK, the reason why I asked was that I searched for this string from your message:
Faulting module path: C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146\mfc90u.dll
...and there are a lot of messages (most I found happen on Dell), and it seems like this message is not only appearing for AutoCAD. It starts with reinstall new drivers up to defect files on harddisk.
I'm not sure at the moment (to less info), but maybe it's the best way to reinstall your pc. But let's first wait for other opinions.
- alfred -
Alfred NESWADBA
eherc
Message 13 of 31 (871 Views)
06-08-2012 04:50 AM in reply to: Alfred.NESWADBA
Did the reinstall already, but the problem remains.
antoniovinci
Message 14 of 31 (865 Views)
06-08-2012 05:11 AM in reply to: Alfred.NESWADBA
My dear, I can't find a logic connection between a software error, and the hardware brand: would you elaborate it, for my childlike curiosity..?
Danke schoen !
Alfred.NESWADBA
Message 15 of 31 (864 Views)
06-08-2012 05:11 AM in reply to: eherc
I meant Windows-reinstall, not AutoCAD Map3D. I think it's more hardware-depending than you could repair with a Map3D-reinstall (just a feeling).
Sorry, - alfred -
Alfred NESWADBA
Alfred.NESWADBA
Message 16 of 31 (862 Views)
06-08-2012 05:17 AM in reply to: antoniovinci
I search for the words shown above in the error message, checked a few links that Google returned for this message and for what I scanned roughly my feeling was that most had a Dell having the problem.
And I didn't say it's a problem of Dell, I requested it because that might be an option of where to search more detailed.
Anyway, I'm not sure (or better I don't think) that it is a problem based on Map3D. All threads showing this error have some problems with interfaces between hardware and os, so either the driver or the hardware itself are listed as reasons (again: in the threads I scanned with a fast eye).
- alfred -
Alfred NESWADBA
eherc
Message 17 of 31 (862 Views)
06-08-2012 05:17 AM in reply to: Alfred.NESWADBA
Did both Windows and Autocad Map.
Alfred.NESWADBA
Message 18 of 31 (859 Views)
06-08-2012 05:22 AM in reply to: eherc
Ok, that makes me more sure you have either a hardware- or a driver-issue or there is any software installed creating conflicts with Map3D or DLL's installed by Map3D.
It seems that my help now ends (as long as I don't have direct access to this pc). I would now start
a) installing Windows7
b) let it update whatever it finds as necessary Servicepacks
c) install AutoCAD Map3D
d) install AutoCAD Map3D servicepack
e) check it's functionality
....as long as it's working install the next software-packages you have to install - and after every package retry Map3D
Good luck, - alfred -
Alfred NESWADBA
eherc
Message 19 of 31 (859 Views)
06-08-2012 05:23 AM in reply to: antoniovinci
Dearest Antonio. To satisfy your curiosity, I shall delve into Fountains of Computing Knowledge. The silky matter that connects software and hardware is called drivers, and besides the Driver Forest, it is found in almost every computer in the existence. So this could be a driver issue, and that is even one of several likely explanations.
Please don't hesitate to ask more questions, I will answer as soon as I find time.
Alfred.NESWADBA
Message 20 of 31 (854 Views)
06-08-2012 05:36 AM in reply to: eherc
one addition to my "how would I start now"-message:
It may be important to not start with the pc's delivered "Reinstallation Disk" if you have one. Because that would reinstall the same drivers you had.
Also try to not use the driver cd's/dvd's you already used for installation of the drivers, Instead try to get current ones (or even older ones) from the wwww.
Have a nice weekend and success!  - alfred -
Alfred NESWADBA
