AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD MAP 2010 64 bit - There are no valid MS Jet providers installed
4 REPLIES 4
kenneth.lau
1683 Views, 4 Replies
I am using AutoCAD MAP3D 2010 64 bit. My Jet 4.0 cannot work, any workaround?
Kenneth
4 REPLIES 4
in reply to: kenneth.lau
That's because MS dropped the Jet drivers in 64 Bit
OS, Look for an ACODE driver or similar.
I
Kenneth
I have the same problem. What is the ACODE driver? Is there a possibility to get access to excel and access-files for MAP3D 64bit an vista 64bit? Has anybody found a driver?
Michael
phmurphy
in reply to: MichaelRembe3420
What it an ACODE driver and where do you get it?  I don't find anything with a Google search.
braudpat
in reply to: phmurphy
Hello
Just an idea :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18307898&linkID=9240857
I have installed this MS Access Engine 64 bits on MAP 201x & CIVIL 201x 64 bits ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
