Hello
When the task "acad.exe" is growing and approaching 1.3-1.6 Gb of Ram
you will crash at every time !
Even if you have yet 500 Mb of memory Ram available !
because you are on a PC with 3 Gb Ram and Win XP Pro ...
This is TRUE with any version version of AutoCAD (2000-2011)
and any type : ACAD, LT, MAP, CIVIL, ADT
It's because the bad memory management of AutoCAD, memory leaks, etc ...
and a little bit Windows too ...
So the only solution when you will approach this limit,
is to switch to the 64 bits version of your AutoCAD
on a PC with 6-8 Gb Ram
Bye, Patrice (A very old user of AutoCAD, since R1.4)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
