AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD crashed when open a DWG file
3 REPLIES 3
332 Views, 3 Replies
FATAL ERROR: Unhandled e0434352h Exception at fd989e5dh
When open a DWG file in Autocad 2013
Thanks for any efforts posts!!
3 REPLIES 3
braudpat
Hello
Welcome to the Autodesk/AutoCAD forums !
- If you have "only" an AutoCAD, it's not the right Forum !
If you have an AutoCAD MAP, it's OK !
A few suggestions ...
- Please open your DWG in RECOVERY Mode
and Re-Save it ...
- If AutoCAD 2013, have you installed the SP 2  ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21764214&linkID=9240618
- If AutoCAD MAP 2013, have you installed the SP 2.1  ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21949876&linkID=9240858
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
antoniovinci
Wait, wait, wait: does that error affect EVERY opened drawing, or only a single one?
You may have to take it a step further:
Once you open with Recovery, if you cannot save the file still, try "Send" -> "eTransmit"
Save it in the same folder as your dwg.  Extract the resulting zip file and open the dwg.  This usually works for me and still keeps and FDO resources you have connected.
Good luck!
”Boost
