AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Autocad assigning random lineweight to map polygons
5 REPLIES 5
Group1341
520 Views, 5 Replies
I have connected a ploygon shapefile of lakes, assigned a style, but when I plot, any polygon touching my viewport edge seems to have a random lineweight assigned. Additionally, as you can see in the attached image, I am getting a boundary along the viewport edge. Any ideas?
Thanks very much!
Tags (3)
5 REPLIES 5
braudpat
in reply to: Group1341
Hello
Q1) Which ACAD MAP ?
Q2) And with which Service Pack ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Group1341
in reply to: braudpat
Hi Pat,
I am using AutoCAD Civil3D 2014 service pack 1
Product Ver: I.108.0.4, SP1
braudpat
Hello
There is a SP 2 for CIVIL 2014 !?
http://knowledge.autodesk.com/support/autocad-civil-3d/downloads/caas/downloads/content/autodesk-C2-...
But I believe that it will not solve your problem ?
Q1) I imagine you have no problem in Model Space ?
Q2) I imagine if you zoom/pan a little inside the MVIEW the SHP lines affected by the weight will change !?
If YES, I think it's a bug !
Q3) Can you test with CIVIL 2012/2013/2015 ?
Q4) Can you share with US your SHX/SHP/DBF files ?
Patrice BRAUD
Group1341
The issue only arises when I plot, from layout or model space. The problem is not apparent until I try to PDF the drawing.
 If you are familiar with Map3D, simply connect this SHP dataset (CANVEC) and style the polygons, then try a plot. I'm quite sure this is a bug. I am not able to share the DWG file as they're for a confidential project.
Alfred.NESWADBA
I can reproduce the issue with Civil 3D 2014 as well as with release 2015 (have not tested Map 3D now).
What I found out as workaround is to assign the lineweight of the polygon boundary to be in "Map" size context (and not in "Device" context.
These settings made my PDF's ok:
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
