AutoCAD Map 3D General Discussion
Active Contributor
Earl.Morrill
Message 1 of 6 (298 Views)
AutoCAD Add-Ins in Map
298 Views, 5 Replies
03-12-2012 12:28 PM
I'm running several flavors of AutoCAD.
I installed some add-ins from the Exchange site into vanilla AutoCAD.
Now they are showing up in Map, but each on it's own individual Add-Ins tab.
I now have 7 Add-Ins and 1 Plug-Ins tabs.
1 - I didn't think the add-ins would work in anything but vanilla AutoCAD (or is it you just can't access them through Exchange?).
2 - is there a way to get them all on one tab (I tried in the CUI but didn't get it to work)?
Earl
Product Support
SethHall
Message 2 of 6 (223 Views)
Re: AutoCAD Add-Ins in Map
04-10-2012 06:30 AM in reply to: Earl.Morrill
If you are looking for support for issues caused by Exchange APPs, then you will need to open up EXCHANGE and search for the apps you have downloaded. Depending on who created this App you downloaded from Exchange you will find the Download Details will list the Customer Support email address. For example under Minesweeper the Customer Support will be labs.plugins@autodesk.com. Please contact the App creator and they will be happy to help.
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
Active Contributor
Earl.Morrill
Message 3 of 6 (220 Views)
04-10-2012 06:33 AM in reply to: SethHall
Thanks Seth.
Valued Mentor
TerryDotson
Message 4 of 6 (201 Views)
04-11-2012 07:30 AM in reply to: Earl.Morrill
The problem only occurs in verticals like Map/Civil3D and it didn't get fixed in 2013 !!!
Active Contributor
Earl.Morrill
Message 5 of 6 (197 Views)
04-11-2012 07:41 AM in reply to: Earl.Morrill
'Doh!
Thanks Terry, I guess I will learn to live with it until 2014, or just not use any of them.
Earl
Valued Mentor
TerryDotson
Message 6 of 6 (185 Views)
04-11-2012 03:23 PM in reply to: Earl.Morrill
At least it's cosmetic and doesn't affect anything important, as opposed to ...
http://forums.autodesk.com/t5/AutoCAD-2011/Autocad-gives-the-wrong-area-for-a-polyline/td-p/2978008
... which has been a bug since AutoCAD 2011 and shows no sign of being corrected.
