Hi folks,
Hit another issue with AutoCAD Map 3D 2011. We have several different profiles that have different tool palettes available to the user for different functions. These swap and change neatly without any issue, until you minimise the tool palette.
Once the tool palette has been minimised the first time in a session everything appears to be fine, the tool palette pops back out when required. However, as soon as you change profiles, the tool palette is dead. It appears, but it does not unhide, and if you take focus away from the AutoCAD Map 3D window and then give focus back, the minimised palette has disappeared entirely. The user then has to press Ctrl+3 to get the tool palette to return. Naturally this is very frustrating for the user because they don't want to have to be doing that every single time they change profiles. The only other fixes are for them not to minimise the palette in the first place, but then they have to work with a limited model space or restart Map 3D.
I've attached a few screenshots of what I'm seeing to help.
Is this something that anyone else has experienced, and if so, have you managed to a fix for it? Or if you haven't had it before does anyone have a suggestion as to how I might remediate this particular issue?
Thanks in advance!
