AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AuotCAD Map 3d - 2008 - thematic mapping
3 REPLIES 3
NanCACS
249 Views, 3 Replies
when I attache the database to the drawing and try to use the thematic
mapping it quires just fine, but the hatch will always come to front
when trying to print the map or to create a pdf file. I tried different
pdf creators and draw order, nothing seems to work.
3 REPLIES 3
matTech
in reply to: NanCACS
send to the polyline and hatch to back then regen
Make sure you have line merge turned on if the pfd
plotter properties. This was an issue in 2008 so you may want to be sure you
have the latest service packs installed also.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
when
I attache the database to the drawing and try to use the thematic mapping it
quires just fine, but the hatch will always come to front when trying to print
the map or to create a pdf file. I tried different pdf creators and draw
breauxg
I have the same issue, been having it for years.
I have tried everthing in the book. did you have any luck? Edited by: breauxg on Jul 30, 2009 7:29 PM
”Boost
