AutoCAD Map 3D General Discussion
Active Member
yuenkilau
Message 1 of 8 (185 Views)
Attrubte Table
185 Views, 7 Replies
05-06-2013 11:46 AM
I tried to bring in a shapefile to AutoCad Map 3D 2013 and I realized the attributes in the table were incorrect.  There should be no negatives for the column CLN_NUM_ID.  And it appeared that the CLN_NUM_ID is totally incorrect.  Then I realized the data type of CLN_NUM_ID is Long integer so I changed the datatype to DOUBLE in ArcMap.
When I brought in the shapefile, the program crashed.
antoniovinci
Message 2 of 8 (179 Views)
Re: Attrubte Table
05-06-2013 01:07 PM in reply to: yuenkilau
Zip the triplet SHP-DBF-SHX and attach it here, sir, we're gonna take a look at.
Active Member
yuenkilau
Message 3 of 8 (176 Views)
Re: Attrubte Table
05-06-2013 01:14 PM in reply to: antoniovinci
This shapefile contains the new column i added using ArcMap.  The new column is called CLN_NO_ID and the data type is Double.
braudpat
Message 4 of 8 (169 Views)
Re: Attrubte Table
05-06-2013 01:53 PM in reply to: yuenkilau
Hello
Please we need SHP-DBF and SHX NOT the SBX !
Bye, Pat
Bye, Pat
Active Member
yuenkilau
Message 5 of 8 (165 Views)
Re: Attrubte Table
05-06-2013 02:24 PM in reply to: braudpat
Opps, wrong attachment!  Here you go!  Thanks a lot!
braudpat
Message 6 of 8 (162 Views)
Re: Attrubte Table
05-06-2013 02:54 PM in reply to: yuenkilau
Hello
Strange with MAP 2012 :
- I can import (MAPIMPORT) 370 objects but I see nothing !
- With the FDO driver, the files cannot be used !
I think something is wrong with your SHP-SHX-DBF files !?
Bye, Pat
Bye, Pat
Active Member
yuenkilau
Message 7 of 8 (151 Views)
Re: Attrubte Table
05-06-2013 03:58 PM in reply to: braudpat
Ok.  Attached is the original file i downloaded from DataBC (I just downloaded it again).  The shapefile seems to be fine when opened in Arcmap.  But the column CLN_NUM_ID got messed up when I tried to open it in AutoCad Map 3D 2013.
Thanks!
Active Member
yuenkilau
Message 8 of 8 (150 Views)
Re: Attrubte Table
05-06-2013 03:59 PM in reply to: braudpat
sigh, fail to upload the files as they are a bit large.
http://www.data.gov.bc.ca/dbc/catalogue/detail.page?config=dbc&P110=recorduid:173567&recorduid=17356...
MTA - Mineral Titles Client Tenure XREF
This is the shapefile i downloaded from DataBC.
