I tried to bring in a shapefile to AutoCad Map 3D 2013 and I realized the attributes in the table were incorrect. There should be no negatives for the column CLN_NUM_ID. And it appeared that the CLN_NUM_ID is totally incorrect. Then I realized the data type of CLN_NUM_ID is Long integer so I changed the datatype to DOUBLE in ArcMap.
When I brought in the shapefile, the program crashed.
Zip the triplet SHP-DBF-SHX and attach it here, sir, we're gonna take a look at.
This shapefile contains the new column i added using ArcMap. The new column is called CLN_NO_ID and the data type is Double.
Hello
Please we need SHP-DBF and SHX NOT the SBX !
Bye, Pat
Patrice BRAUD
Hello
Strange with MAP 2012 :
- I can import (MAPIMPORT) 370 objects but I see nothing !
- With the FDO driver, the files cannot be used !
I think something is wrong with your SHP-SHX-DBF files !?
Bye, Pat
Patrice BRAUD
Ok. Attached is the original file i downloaded from DataBC (I just downloaded it again). The shapefile seems to be fine when opened in Arcmap. But the column CLN_NUM_ID got messed up when I tried to open it in AutoCad Map 3D 2013.
Thanks!
sigh, fail to upload the files as they are a bit large.
MTA - Mineral Titles Client Tenure XREF
This is the shapefile i downloaded from DataBC.
