AutoCAD Map 3D Forum
Welcome to Autodeskā€™s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Showing results forĀ
Did you mean:Ā
Attribut Rotation
7 REPLIES 7
Message 1 of 8
teflon
787 Views, 7 Replies
Attribut Rotation
Using Enhanced Attribute Editor one can set attribute text rotation to 0 when the block is rotated. But it must be done for each block individually. Is there a way to do this for several blocks at the same time or globally?
I know making block or text annotativ does it but it requires redefining block, something I do not want to do.
7 REPLIES 7
Message 2 of 8
antoniovinci
in reply to: teflon
You should only select those rotated blocks, then _PROPERTIES, and set 0 as "common" rotation angle, sir.
Message 3 of 8
teflon
in reply to: antoniovinci
What I mean is a way to change rotation for attribute globally regardless rotation of the blocks.
Blocks are rotated differently but the attributes should stay at rotation 0 or to be able to be set to 0 afterwards.
Message 4 of 8
Murph_Map
in reply to: teflon
Dynamic blocks will do that, however you can not use them for point styles and get it to work. One way is to turn off the attributes display then create labels set those to 0 rotations.
Murph
Supporting the troops daily.
Message 5 of 8
antoniovinci
in reply to: teflon
I gotcha, sir.
Of course, Murph's "dynamic" advice is very elegant, but let me give you an "old-school" one.
You could select and save only the rotated blocks thru the _DXFOUT command (beware, Ascii format NOT binary), then in Notepad (or better text editor) you can search and replace the angle items, save and open back this modified DXF in Autocad.
Message 6 of 8
teflon
Thanks!
It worked!
But I did not find different formats of DXF.
I had already tested ATTOUT/ATTIN but it just changes the value of attribute not the rotation.
Message 7 of 8
antoniovinci
in reply to: teflon
The DXFOUT suboptions are under the Tools menu:
Message 8 of 8
teflon
And how do I find my blocks? There are lots of stuffs in there!
ā€Boost
