AutoCAD Map 3D General Discussion
New Member
0 Kudos
Post 1 of 2
Assign Global Coordinate System, Select Coordinate System, no list of Codes
640 Views, 1 Replies
04-19-2012 09:41 PM
Using AutoCAD Map 3D 2011 and attempting to set the Coordinate System with Assign Global Coordinate System.  The problems are that the Select Coordinate System... button does nothing.  I assume is should load and display a list of codes and coordinate system and then the user select the desired code.  But since no list displays there is no way to see the codes.  I have searched on the forum and found a list of codes but manually entering a code generates the error “Can't save projection for current session.”
Is there some installation issue or some other way to set the Coordinate System (NAD 83 Zone 3N)?
194 Kudos
Post 2 of 2
Re: Assign Global Coordinate System, Select Coordinate System, no list of Codes
04-19-2012 10:30 PM in reply to: JeffEnge
Did you just apply the last Service Pack?
If it doesn't help, you should uninstall and then reinstall the whole package, sir.
