I have some shape files witch contain contour lines.
They appear as linestrings, but they have not a Z value. The Z value appears as a feature property with a Name witch in my case is "CONTOUR" and the value is a number witch represent the contour elevation.
When i try to create geometry from Feature it extract a polyline with a 0 Elevation.
How can i assign the feature property "Contour: as an elevation to the extracted polylines?
I want to do this with an automatic way with all the linestrings.
Thank you for your answers.
Solved by Murph_Map. Go to Solution.
Solved by parkr4st. Go to Solution.
This should lead you towards your answer.
https://map3d.wordpress.com/2007/09/26/contours-from-shape-files-with-elevations/
An old post but still the way to do it.
Thank you very much. That's exactly what i need.
Instead of thanks I'll take the Kudos, I can use those like Green Stamps and am a little short on getting the new liquid pen set. 🙂
