Hi there!
Hopefully someone can help on this one. I'm relatively new to AutCAD map 3d but I've used arcGIS a while back.
I have existing roads, towns etc data that are already set to UTM 17. I want to import ascii point coordinates (from a comma delimited file) into the file. I can import the ascii coordinates as points fine (easting and northing), however the points come in as the absolute coordinates rather than geometric coordinates. I already set the files for right geographic projections. Beyond manually inputing the coordinates into the coordinate tracker, is there a way to import the coordinates form the file set for the geometric coordinates?
Thanks in advance!!
J
Have you assigned the coordinate system to your dwg and the text file you are importing into?
Yup. I've assigned the same coordinate system to both the drawing and when I import the ascii coordinates into the survey data store.
