AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Array Ribbon
2 REPLIES 2
632 Views, 2 Replies
Array Ribbon
Is it possible to display the ribbon (ARRAY) in AutoCAD MAP 2012 as occurs in AutoCAD 2012?
Thx.
2 REPLIES 2
Albert_Rius
Please can you check this discussion?
http://forums.autodesk.com/t5/AutoCAD-Map-3D-Wishes/Add-contextual-associative-array-tab-to-AutoCAD-...
It's related the same problem.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
in reply to: Albert_Rius
Hi, Albert.
Thank you very much. It's just what I wanted!!!
”Boost
