AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Array Ribbon
2 REPLIES 2
manuelbalonso
631 Views, 2 Replies
Array Ribbon
Is it possible to display the ribbon (ARRAY) in AutoCAD MAP 2012 as occurs in AutoCAD 2012?
Thx.
2 REPLIES 2
Albert_Rius
in reply to: manuelbalonso
Please can you check this discussion?
http://forums.autodesk.com/t5/AutoCAD-Map-3D-Wishes/Add-contextual-associative-array-tab-to-AutoCAD-...
It's related the same problem.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
manuelbalonso
in reply to: Albert_Rius
Hi, Albert.
Thank you very much. It's just what I wanted!!!
”Boost
