AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Area Precision
12 REPLIES 12
Message 1 of 13
PatrickManson
1174 Views, 12 Replies
Area Precision
I have defined map annotation text which shows a Lot number and an area. The data is attached to the polyline, and the Lot number is manually entered in via the properties pallete. The area field comes from the area of the polyline. I am struggling to figure out how to get the area shown to 0 decimal places, and also to add a m² suffix to all of the areas.
Can anyone help with this?
Cheers, Patrick
12 REPLIES 12
Message 2 of 13
Ok, i have figured out the precision - but can anyone help to add the m² suffix?
Thanks.
Message 3 of 13
Murph_Map
in reply to: PatrickManson
If you are using map anno blocks I would use Mtext for M2  (M\u+214A) and right justification for the attribute.
Murph
Supporting the troops daily.
Message 4 of 13
Hi Murph, thanks for the reply. I have defined the template using mapanntext, the first line picks up the Lot number previously defined, and the second line picks up the area of the polyline. I am not sure how to add the area of the polyline as a field to mtext in the block editor as you cannot select the polyline to link it to using that method. I cannot add the m² to the end of that as mtext as it is not linked to the size of the area, so if you have a large area it is over the top of the m².
My mapanntext is (rtos .area), how can i add that as a field into a mtext?
Thanks, Patrick
Message 5 of 13
I have finally figured this out. This is expression value in the mapanntext dialog
(strcat (RTOS .AREA 2 0) "m²")
Thanks for your help everyone.
Patrick
Message 6 of 13
Murph_Map
Patrick
I tried that way as well but couldn't get the 2  on the M2 to half size. 🙂
As for the scale of the mtext uae the same size as the attributte then when you insert use scale option and scale based on the area.
Murph
Message 7 of 13
antoniovinci
in reply to: Murph_Map
Here you have the right Unicode syntax, my dear:
(strcat (RTOS .AREA 2 0) "m\U+00B2")
Message 8 of 13
Murph_Map
in reply to: antoniovinci
Thanks sweety.
Murph
Message 9 of 13
antoniovinci
For the newbies, the full list of Unicode codes is available by means of:
WIN-R => CHARMAP
Message 10 of 13
Hey,
I'm working with your formula, I need to use 2 decimal instead of "no decimals". So what does the 2 0 stand for?
(RTOS .AREA 2 0)
I tried typping (RTOS .AREA 2 2) for 2 decimals, but it didn't work, can you tell me the correcto formula?
Message 11 of 13
PatrickManson
Hi Sorry, i cannot even remember where you enter that formula in! i have played around with my template, but cannot see where to do that anymore - if you can help with where you enter the formula i will see what i can do.
cheers
Message 12 of 13
I have also been working on this and successfully edited the formula to produce 3 decimal places.
(strcat (RTOS .AREA 2 3) "m²")
See screen shots.
Hope this helps.
Paul
Message 13 of 13
O_Eckmann
Your formula is correct (rtos .AREA 2 2)
but you should be careful with DIMZIN variable because RTOS (lisp conversion function) read DIMZIN value to remove (or not) 0 value at the end.
By default DIMZIN is set to 8, so if you have a real value 12.5 and use (rtos 12.5 2 3) you obtain  "12.5".
If you want to obtain "12.500" you should set DIMZIN to 0, then rtos convert with good number of decimal even with 0 value.
Olivier
Olivier Eckmann
