AutoCAD Map 3D General Discussion
Member
lbutler4
Message 1 of 7 (775 Views)
ArcGIS versus AutoCad Map
775 Views, 6 Replies
09-20-2011 10:28 AM
I work for the county assessor in the map rooom and we make changes to tax maps.  We used AutoCad Map to make the changes but now an ESRI GIS has been compleded and the assessor doesn't want us to use AutoCad Map.  I'd rather use AutoCad Map.  Does anybody have a good argument for using AutoCad Map?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 7 (771 Views)
Betreff: ArcGIS versus AutoCad Map
09-20-2011 11:01 AM in reply to: lbutler4
if I'm very bad: Map3D can plot :smileywink:    ... without buying ArcPress or something like that.
Map3D is the much better option when you have to handle/modify geometry. Beginning with a mass of objectsnap-variations, all modify-functionality with grips, ... you are done with geometry-work very very faster (incl. better quality) than you will be able to do with ArcVIEW/ArcGIS.
So all work operating on geometry will be easier and faster done with Map3D.
Than there is the part of stylization and analysation and data-amount, that are items of where it's hard to beat. Even with Map3D2012, which is real good in flexibility of stylization, at the point you create a thematic map and/or use labeling (lot of text) the performance if Map3D is more data-amount-depending than ArcXXX.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
antoniovinci
Message 3 of 7 (751 Views)
09-20-2011 11:21 PM in reply to: Alfred.NESWADBA
I completely agree with you, herr Alfred.
Maybe the weakest aspect of Map, in comparison with Esri tools, is about the raster management: for instance, Arcgis is able to handle gigabyte images .ECW in real time, whereas Map crashes or doesn't open them at all.
Active Contributor
MMorrison
Message 4 of 7 (665 Views)
Re: ArcGIS versus AutoCad Map
10-05-2011 01:34 PM in reply to: lbutler4
AutoCAD Map does edits far easier than ESRI.  You can possibly edit the ArcGIS directly if you like (depends on setup/permissions/etc)  If you would like, send me a note off-list and we can talk.
Martin
Member
lbutler4
Message 5 of 7 (636 Views)
10-06-2011 06:24 AM in reply to: MMorrison
I tried sending MMorrison a private message but I get an error message that says he has a duplicate screen name. I pick MMorrison but I still get the error message.
Member
lbutler4
Message 6 of 7 (633 Views)
10-06-2011 06:25 AM in reply to: lbutler4
My e-mail address is lbutler4@assessor.state.wv.us
Active Contributor
MMorrison
Message 7 of 7 (632 Views)
10-06-2011 06:26 AM in reply to: lbutler4
Send me an email then at martin dot morrison at edsi dot com.
Martin
Post to the Community
New Post
Need installation help?
