AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Anyboy else experiencing Memory problems?
1 REPLY 1
c.schmidt
568 Views, 1 Reply
Hi @all,
Me and my company have recently updated to Map 3D 2012. (from 2011)
After testing a lot, i figured out that the client fills my RAM until it is full,
though i am not doing any big interaction. Just strafing over some points
let the used memory of the Acad-process increase by 3-4MB per second.
Second big problem which we have is using snap functions on enhanced stylizations
like point symbols and so on.
E.g.: My co-worker has to create a huge amount of aligned dimensions.
Therefor he uses the snap-functions to snap start and endpoint of the dimensions.
After some time (and dimensions) the app crashes. sometimes after 1 hour,
sometimes every 5 min.
The Autodesk support says, that this "memory leak problem" should be solved with
SP1 but it isn't for me. Also for the problems with dimensioning they say, that they
have heard of some users who have the same problem, but can't provide a solution.
Probably anybody in this forum is experiencing the same problems and can provide any hint?
System information: Intel I7, 8GB Ram, ATI firepro V4800, Win7 x64, AutoCad Map 3D enterprise 2012 x64 SP1
1 REPLY 1
sanudy2011
in reply to: c.schmidt
HI, c.schmidt ,
    We too have faced similar problems using and we had worked out some changes in our systems which didnt requred much updation in the system.
Firstly , we had free the space in local drive where the Autocad has been installed and asked the user to avoid the users to save data on other drives so that Autocad can function normally, Usually Autocad a huge amount of usage back hand, hence we found the only solution to make it work is to provide as much as free space we can.
Secondly try deleting the temp files created by Autocad on the given location:-
del/q "C:\Documents and Settings\All Users\Application Data\Autodesk\AutoCAD Map 3D 2009\R17.2\MapCache\*.*"
You can add this in batch file which the user can run on some time intervals.
Thridly: In Autocad option menu you would find some sub menus which allows the users to change the saving path for temp and external files. refer the sanpshot. this frees the local memory of the machine hence avoids the shutdown of Autocad.
Hope so this helps.
Santosh Udyavar
Rolta India Ltd
Mumbai.
”Boost
