So I would like to assign the layer text goes on when using an annotation template by the polygon that is being labeled. I can do that by putting .layer in the expression box for the layer in the template. I would like to take that a step farther and have the annotation template label go on an appended layer based on the polygon being labled. So if the polygon is on layer "own", I would like to somehow put the annotation template on a "own-t" layer. I know I can just specify the layer "own-t" but I don't want to create a annotation template for every type of control that I have (own, lease, etc.). Does this make any sense, and is it possible.
Thank you,
Kraig
Solved by jagielski. Go to Solution.
Try using this expression (STRCAT (.layer " -T"))
My Map3D needs a repair install or I would of tested it first before replying.
Murph,
Thanks for the reply. I had tried that. I tried again, checking sytex. I get a warning message saying Missing quotation mark in the expression, and it ignored the expression and puts the label on the "0" layer.
I don't know much about using expressions, but I've tried a series of different ways trying to concatenate the .layer with "-T" with no luck.
Thank you,
Kraig
Well, I tried again and now I'm getting an "Unsupported operator specified in expresion: .layer" warning message.
