I am pulling my hair out trying to figure out what is wrong with this annotation template! I am building a map of our electric utility system, and I've got a huge drawing with many annotation templates in it which label poles, street lights, etc. All of them are working correctly except one and I can't figure out what's going on.
I have two different blocks for two different types of street lights. The annotation for one block is working fine. However, the annotation for the other block is not showing up.
I have used the "Define Annotation Template" dialog box. I have defined which layer it is to go on, and set up the value as the block attribute for this block. When I go to insert the annotation, it says "1 annotation object inserted' but nothing shows up. I can't see anything on the screen to select it, but it will select the block if I do a "qselect".
The layer that the annotation template is inserted on is definitely turned on and active. The text height is exactly the same as the other annotations which are working correctly. I have tried building a whole new block, completely re-defining the annotation template, and nothing seems to work.
Can anyone shed some light on this? Help me think of something I might have missed??
when you qselect block, check scale. it might be that it is too small.
can you send a part of your dwg, maybe i can find something.
I finally figured out why this wasn't working. I the block attribute that I was trying to display in the annotation template had a "#" in it. I renamed it, spelling out "number" instead of the "#" sign, and the annotation template worked fine after that. I guess the symbol threw it for a loop!
