AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Amend intervals in contour generator
3 REPLIES 3
Ste_EDFER
610 Views, 3 Replies
Morning all,
I've imported and converted a XYZ file into a 3D surface and now want to create a contour layer. How do I change the default values in 'generate contour' as my height difference is only 8m and want my contour elevation intervals to be 1m as oppose to the lowerest on the drop down which is 10m.
Many thanks in advance for any help 🙂
3 REPLIES 3
alexlibrelon
in reply to: Ste_EDFER
Good Morning.
What is the file format you have like surface?
Alex Librelon
Projetista Master - Youtube | Blog | Linkedin
- Marque a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Clique em "Curtir" caso a resposta tenha ajudado;
alexlibrelon
Morning, all.
If the format is .tif follows:
Mapconect
Add Raster Image or Surface Connection
Added with the surface:
MapWspace
In Task Pane -> Display Manager
Select the surface in the Task Pane
With the right mouse button and choose Create Layer Contour option ...
In the dialog box Generate Contour
Change: Elevation Contour interval: 1 Meters
Change: Major Contour every: 5
Select path to save the .sdf file and click OK.
Result:
Click Accept the Solution, and kudos if this answer solve your problem. Thank you.
Alex Librelon
Ste_EDFER
in reply to: alexlibrelon
Many thanks for your reply,
I was doing exactly as you described below BUT I didn't know you could manually type in a value in the "contour elevation interval" panel, I thought the drop down was static.
Thanks again
”Boost
