AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
alter properties/define text/object data-records
1 REPLY 1
196 Views, 1 Reply
Can this be done? I have a table with a field with two records in each. Is there a way to call up records one and "strcat" it to record two? Thanks, TC
1 REPLY 1
Yes, this is a common type of usage for Map
expressions.   And, since
our expression language is modelled on AutoLISP,
the syntax and usage
is almost exactly like you've guessed
below.
You want to concatentate two (presumably) character
fields from object
data.  Use something like the following for
the text value in the property
alteration:
    (strcat :field1@odtable
:field2@odtable)
where "field1" & "field2" are the field
names, and "odtable" is the table name.
Cheers-
rdh.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Can
TC
”Boost
