I can import object data as text into a drawing using a query. The only
options for the text rotation that I see are to specify the rotation angle.
I was wondering if it is possible to align the text resulting from the
object data with the object that it originated from.
Also I want to know if it is possible to query in two fields of object data
into on text entity. i.e.. can I concatenate two fields of object data into
one text entity. For example: I have object data with the street name in one
field and the street type (St., Ave., Ln, etc.) in another field. I was
hoping to get the text resulting from the query to read "Street_name type"
(e.g.. Main Rd). In excel you can concatenate text using the "&" symbol is
there a similar thing in AutoCAD MAP. Alternatively is it possible to
manipulate the object data to end up with a new field with the concatenated
text in.
Any assistance would be appreciated.
Sean Bartleet
