AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
all objects turn grey Map3D 13
4 REPLIES 4
davidm889
1563 Views, 4 Replies
After setting up a layout tab, all of my objects turned light grey. When I went to model space they were the same. if I list an object the color says bylayer but the display (in model space or in paperspace remains grey even afret doing a regen, or closing the drawing and reopening it.
4 REPLIES 4
Murph_Map
in reply to: davidm889
Check in the page setup manager and see if you checked "Display Plot Styles" . Uncheck it if it is.
Murph
Supporting the troops daily.
psreereddy
in reply to: Murph_Map
davidm889
in reply to: psreereddy
Ok, that worked, what the heck is that???  Long time AutoCAD user but I'm new to using MAP3D
geocadlt
Had a problem - all objects in Model space were of a grey color, not displaying color explicitly assigned to them (e.g. red).
Unchecking "Default" in Map Taskpane really helped.
Thanks.
”Boost
