i have my map set to show the aerial map through autodesk 360. today it doesnt display the aerial when i open my map, any reason why
Solved by phil_borycens. Go to Solution.
Hi all,
Thank you for reporting this. We discovered this yesterday and immediately notified the Division responsible for the source code.
We have a bulletin being published and will update it as soon as we have more news to share:
http://knowledge.autodesk.com/article/Live-Maps-No-Longer-Appear-outage
Phil
Yes. Yesterday our developers spent their day rewriting code for the Bing API (used in AutoCAD) to utilize TLSv1 rather than the SSLv3 protocol. It appears that Microsoft dropped SSLv3 support in reaction to POODLE attack vulnerability.
We will update you when a fix is made available.
A fix is targeted for the end of this week (Nov 7th).
When the fix is live, AutoCAD users should see a message indicating that a fix is available when trying to use any of the Geolocation functionality.
A fix has been provided to restore Bing Live Maps. When activating the Online Map in an AutoCAD drawing, the program should prompt you to get download the fix.
Here's a quick demo for how to download & apply the fix.
I downloaded the upgrade that kept popping up and now I don't even have the Geolocation tab. It's been replaced with BIM 360 which is something I don't even need.
Which version of Map3D do you have and which upgrade have you downloaded (there exist more in the meantime).
- alfred -
