I have recently migrated to AutoCAD Map 3D 2012. In the previous version I had a drop-down menu that was for Adobe that contained a much-needed batch convert tool. When I migrated over, it was no longer present, nor was the Adobe toolbar. I've tried to run the Repair & Modify functions through Control Panel and it did nothing. I'm a newby at this software, so I was wondering if I need to register something or a similar task top bring these features back. Also, I have begun using a Virtual Machine instead of a normal PC, if that might have anythign to do with it.
>> I did. Is there any other reason why the functionality might be missing?
A release of Adobe Acrobat that does not support 64bit and you are running 64bit-Map3D?
- alfred -
>> How would I find out if I am running the 64-bit version of Map 3D? Is there somewhere I can look?
If your operating system is a 64bit version then Map3D is it also.
- alfred -
PS: you should remove your signature from your mail system!
